Author Topic: vr6 head  (Read 2358 times)
Offline woody1
vr6 head
« on: 05 February 2011, 20:04 »
does anyone have a step by step guide to removing a vr6 head and installing one ?
how to put cams in , time up , head gasket  etc ?
got a 2.9 ported head and drc 268 cams to fit wondering how easy this is to do or garage jobby ?
......THE 6 CYLINDER CURB CRAWLER......
Offline SoundillusioN
Re: vr6 head
« Reply #1 on: 10 February 2011, 10:43 »
That all depends on you and your capabilities.... Ever done anything like this before on a smaller more simple engine? If not, I don't think i'd recommend taking yours to bits unless its got a problem.   Have you got a Haynes for a VR6, that would be a good start?
Offline AudiA8Quattro
Re: vr6 head
« Reply #2 on: 10 February 2011, 23:59 »
Haynes don't do vr6.
Buy a bentley manual, it has all the info you will need.
Re: vr6 head
« Reply #3 on: 11 February 2011, 00:36 »
Lazy g!ts
Re: vr6 head
« Reply #4 on: 11 February 2011, 08:38 »
Be warned it is not an easy job
Offline DECKED-MK3-DUB
  • 1995 VR6 vento :)
Re: vr6 head
« Reply #5 on: 06 March 2011, 23:04 »
Any chance of any more info as i have a head job comming up on mine i think.. Also where can i get a bently vr6 manual from ? i noticed haynes didnt cover vr6's..... to**ers lol...  :wink:
Offline trackday
Re: vr6 head
« Reply #6 on: 10 March 2011, 17:49 »
it depends how far you gonna go with it,first way remove top timing chain cover and wind off cam chain tensioner and remove chain then remove inlet manifold and exhaust etc or are you going to replace the chain because if so its a gearbox and flywheel job off,i have just done the gearbox on mine on my drive and tbh its a arse,if your not very handy with the spanners give the head ache to someone else, ok it costs more but if it blows up or something aint right you can take it back for them to repair.hope this helps
Spec- Sounds awesome 2800CC VR6 200BHP Remapped with 7300 rev limit. Kent cams, cold air carbon intake kit. Forged pistons,power boost valve,6 branch manifold, de-cat pipe and full powerflow exhaust system.Grooved discs with red stuff pads. Gaz Gold fully adjustable suspension, 3.8 camber at front.
Full race cage, Momo steering wheel and corbeau race seats with four point harness. Fire extinguisher and 4.26 final drive conversion
Re: vr6 head
« Reply #7 on: 11 March 2011, 00:10 »
You can get the manual from ebay or amazon.
