Author Topic: camber question.... one for dmonday....? using washers...  (Read 8282 times)
Offline robz
Re: camber question.... one for dmonday....? using washers...
« Reply #10 on: 05 February 2011, 20:39 »
Ok... Hmm
Difficult! Would longer bolts/stronger bolts compensate??
« Reply #11 on: 05 February 2011, 20:40 »
Ok... Hmm
Yes I guess so.
Offline robz
« Reply #12 on: 05 February 2011, 20:45 »
Right, so if I do it I'll get some decent bolts from an appropriate trader, did the same for my arb bolts lol
Cheers for the advice though mate, don't want another wheel coming off lol
First time was bad enough!!
« Reply #13 on: 05 February 2011, 20:50 »
Stronger bolts will help but you still stressing things more than normal.
Offline robz
« Reply #14 on: 05 February 2011, 20:57 »
Fair enough!!
These ez shims are 25 quid roughly so may try the washers and then if I'm happy With the result Buy the shims!
Offline Gash
« Reply #15 on: 05 February 2011, 21:00 »
this could be handy for me too as when i put the wheels on in the week im not sure how the camber is going to be. if i can adjust it for a few days should be ok!
Offline robz
« Reply #16 on: 05 February 2011, 21:03 »
I wanna get out there and do it now lol
Offline Dmonday
« Reply #17 on: 05 February 2011, 22:29 »
Can't be that much stress, i drive my car quite hard and never had an issue even when i had a pretty stupid amount of camber! I know a lot of people who use this method & a sh!t load use it over on edition but i'm not suggesting you do this as i don't want to be responsible if you crash and burn to death :) stronger / longer bolts would be better but i couldn't be arsed with that so i'm running the standard bolts :)
Dan
Offline robz
« Reply #18 on: 05 February 2011, 22:31 »
lol!!
im up for trying it!
i just NEED camber now!
what thickness washer did ya use?
Offline Jack3559
« Reply #19 on: 05 February 2011, 22:51 »
A 1mm washer on the bottom right bolt gives -4 degrees of camber which is perfect for most.
Or you could do what the ONI camber guys in japan do and chuck a scaffolding pole in above the bolts for -45 degrees.
