Author Topic: Auto choke wont cut off  (Read 1233 times)
Offline chrismk2
  • Mk2 16v
« on: 01 March 2005, 23:36 »
Hi ive got a carbed 1.8 cab and it the auto choke wont stop it decides sometimes to work but in general its revving about 2000rpm i tried to adjust the idle but when it does work the engine then dies(obviously!)
Any ideas????
cheers chris
Re: Auto choke wont cut off
« Reply #1 on: 04 March 2005, 17:48 »
Sounds like the coolant channel o'ring in the inlet manifold has degraded and clogged itself up.  Common fault on carbed models, whip the inlet manifold off and replace it, takes a couple of hours to do.
You need a long thin extension socket with a hex bit on the end, make sure you can get to all 6 bolts before you try though :)
You live anywhere near Bracknell?
Offline chrismk2
  • Mk2 16v
« Reply #2 on: 06 March 2005, 20:11 »
yeah about 20mins away aldershot mate
