Author Topic: New 1.8t Gti owner, need advice.  (Read 1620 times)
Offline alfiemaher
« on: 05 February 2011, 08:34 »
Hi guys, new to this site but was just after some advice. I just bought
a 1999 Vreg 1.8t gti with 80,000 for £1500 it had some valbrem alloys
on which were curbed up and one looked really damaged because it was in
the boot, but were also given original wheels which I have put back on which are
fine.
 The brakes are good and the car seems to run well, but when
I hit around 70-80 the steering wheel has strong vibrations, does
anyone know what it is, or if it's common? I also couldn't find in the
history if it has had a cambelt change either so probably a good
idea to get it changed, how much is a good price and does anyone
live in Kent and could reccomend someone.
Any help would be appreciated.
Cheers guys
P.s: if anyone wants to buy the alloys let me know and I'll send
pictures.
Offline MK4D4VE
Re: New 1.8t Gti owner, need advice.
« Reply #1 on: 05 February 2011, 08:40 »
fine.
Cheers guys
pictures.
Would this just not be balancing? Go to your local tyre shop and get them balanced, wont cost alot.
Golf MK4 1.8 20v GTI
Offline houston
« Reply #2 on: 05 February 2011, 08:50 »
usually speed wobble would suggest the spigot rings, but there definately original?
Offline fleg
« Reply #3 on: 05 February 2011, 10:32 »
I just had my cambelt & waterpump done at VW £399 inc. VAT I'm sure you can find it for £300 in a backstreet garage...
Offline Chris36
« Reply #4 on: 05 February 2011, 11:00 »
Get the front wheels balanced - Cam-belt kit including water pump (£110 odd from TPS) look about paying £100 labour.
Offline vwfiend
« Reply #5 on: 05 February 2011, 11:06 »
Could be a buckle or defective tyre also mate. That was Cheap!!!
Offline b1gdub
  • MK4 1.8T AGU
« Reply #6 on: 05 February 2011, 13:24 »
Mate my advice is get the car to a garage and get them to put it up on ramps and then do a full suspension and underfront checkup. It could be a something real easy and cheap to sort out before you go start spending £££. Wherebouts in kent are you??
There's a vw specialist garage I've just starting using in bexley. This guy nows all bout dubs and has come recommended by loads of guys on here.
Offline alfiemaher
« Reply #7 on: 05 February 2011, 13:36 »
Sounds good, who's the guy in bexley, I'll give him a buzz
because I'm only in West Malling.
