Author Topic: runs bad when I remove the oil cap when running  (Read 1211 times)
Offline palmer
« on: 05 February 2011, 00:26 »
is this normal  ?
was changing the oil  and had engine running after it  had been changed  -- removed the oil cap  and to my  " surprise "  the engine then started to run very badly --- replaced the cap  and all was well again !
that is the reason for this and is it  normal ?
cheers
Rob
Offline Jimmy Filth
Re: runs bad when I remove the oil cap when running
« Reply #1 on: 05 February 2011, 01:44 »
my knowledge isn't amazing on mechanical things, but I understand that if you do this and there is a change of note it can indicate a problem that I know as 'blow back'.
However I have also been told that this is normal, so I don't know what to believe now  :rolleyes:
7R 5 door.  Limestone Grey.  19" Pretoria's, Leather, DCC, Winter pack, keyless entry, rear camera.
Offline stainesy
« Reply #2 on: 05 February 2011, 07:57 »
My golf is exactly the same I think its normal on the golf though.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 05 February 2011, 08:32 »
Its normal.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #4 on: 05 February 2011, 09:22 »
Normal  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 05 February 2011, 13:10 »
Isn't it to do with creating an air leak in what is regarded as a closed loop breather system?
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 05 February 2011, 13:25 »
yep
« Reply #7 on: 05 February 2011, 13:27 »
 :nerd:
Offline Mike87Turbo
« Reply #8 on: 05 February 2011, 18:34 »
A lot of cars do it, not just golfs! Theres a vacuum of air within the breather system on an engine, and if you remove the cap it loses vac pressure, same as a split pipe or similar.
My advice, leave the cap on lol!
« Reply #9 on: 05 February 2011, 19:44 »
To be honest i don't understand why you would remove the oil filler cap whilst it's running anyway?  :huh:
