Golf mk4
Wazzzer
Mk4 Gti coilovers .... Do I need spacers???
Topic: Mk4 Gti coilovers .... Do I need spacers??? (Read 3347 times)
samclark3232
04 February 2011, 21:15 »
Hi I have some fk street coilovers and I was wondering if I can just fit them straight on with no spacers or anything?
Thanks
Sam
1999 Mk4 golf gti (non turbo) 3dr jazz blue, recaro interior, 6 cd changer, Fk Coilovers, 6000k HID Kit
daz veedub
Forum addict
Operation 1.8t bolf
Re: Mk4 Gti coilovers .... Do I need spacers???
04 February 2011, 21:17 »
more than likely need 5mm on front mate
mikemk4gti
04 February 2011, 21:21 »
I can confirm that, with Jom coilovers and 18x8j et35 wheels you definately need front spacers.
I haven't got any yet and I've lowered about 30-40mm on the front, any more and the adjuster ring will be touching the wheel.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
samclark3232
04 February 2011, 23:22 »
I'm running the standard 15" wheels on 195 tyres .... Still need them?
s-l-i-x
Golf MK4 1.8T AGU
04 February 2011, 23:41 »
Im down quite low on standard 16" ronal turbo alloys and 205 tyres. But think it depends on what wheels you have.
I didnt need any spacers. Could always try to reach around the back of the wheel to see if its touching the tyre or not. If it is, make it a bit higher to clear the tyre until you can buy some spacers.
Wayne
Sir Postalot
04 February 2011, 23:54 »
Should be fine on standard wheels.
samclark3232
Reply #6 on:
05 February 2011, 00:06 »
I was just curious because the front start about 3 inch's lower than the originals and of corse they are wider at that point than the standard ones so just wanted to make sure but u recon I will be alright?
vwfiend
Reply #7 on:
05 February 2011, 00:37 »
Mine was fine with anni wheels and 225 tyres dropped and up high pn FK AK's. Very small gap which nomatter how small will never change. Standard wheels will be all good
samclark3232
Reply #8 on:
05 February 2011, 14:26 »
I've managed to fit the rear suspension with pretty much no troubles apart from the Bellend on eBay that I got the spacers off dosent know what he is doing and got the spaces between the wheel bolts completely wrong .... Luckily the rear does not need spacers but the front may do so I will wait till I have the correct ones
Golf mk4
Wazzzer
