Author Topic: 5 door not opening all doors from fob  (Read 1613 times)
Offline squirrelGTi
« on: 04 February 2011, 13:29 »
Hey,
The Mrs has a small issue with her GT.
When she presses fob once, drivers door opens fine.
I thought when you press it twice all doors open?
It appears that we have to press it 3/4 times to get all the doors to open. It's on ever the passenger side, rear door that's an issue.
She only has the small MDF display, so i guess if i needs to be reprogrammed its a vag com job?
Darren
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Offline squirrelGTi
Re: 5 door not opening all doors from fob
« Reply #1 on: 04 February 2011, 14:03 »
Sorry update to the problem.
The other half says that it sometimes doesn't unlock from the button inside the car. If you press it a second time it normally unlocks.
Could it need oiling or something?
Offline Phil1980
« Reply #2 on: 04 February 2011, 14:07 »
My button to unlock the passenger door inside mine, stopped working recently was just a loose connection behind the switch, all sorted now.  May need the fob reprogramming.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline pluslyn
« Reply #3 on: 15 February 2011, 14:31 »
Check spare fob
Also you can program the car with VCDS to open all 4 doors with 1 press.
