Author Topic: Think i may get shouted at for this....  (Read 2128 times)
Offline Kyle!
« on: 04 February 2011, 01:09 »
.... so ...
I have the cutting out problem but im not asking how to cure it before you all go mad at me lol.
I simply need to know if,
1)  There is a way to test the crank sensor before i spend £48 on a new one ie: voltages and ohmages across the wires etc etc...?
2)  How do i disconnect the VW imobiliser as vag com throws up this message:
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
        P1570 - 35-00 - -
        P1570 - 35-10 - - - Intermittent
please dont go mad im not asking you all to tell me how to cure my problem im just a little stuck with these 2 things... ive read soooo many different forums and topics etc my head is spinning there doesnt seem to be much information on one set cure like the imobiliser or the crank or the relay every topic has cures and suggestions for all 3 and maybe more all in one place and is a little confusing at this late hour lol
Cheers Guys
Kyle
http://uk-mkivs.net/forums/p/473515/3251643.aspx#3251643
^^ Clicky For Build Thread (Updated 17/08/12) ^^
Offline mark-mk3gti
Re: Think i may get shouted at for this....
« Reply #1 on: 04 February 2011, 06:28 »
Hi mate
Have u had car stood for ages and battery gone flat? Could be the ecu,immob have forgotten the codes between them, vagcom can cure that, but it looks like u could need a new immob box, I've just changed mine and got that fault when messing about with mine until I pared them again,
if Wayne or rubjohnny see ur problem they will shed more light on it!
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 04 February 2011, 08:15 »
The immobiliser box can be found either behind the passenger glovebox/airbag or behind the clocks. With the engine running disconnect the box and the immobiliser is out but do you have a starting problem because as said the fault codes could be old and just need clearing. I bought mine with 10 fault codes. Cleared them all and drove the car round the block and re checked and had 1 code.
« Reply #3 on: 04 February 2011, 09:30 »
read the codes from the immobiliser box, this will tell you why it is cutting in. i take it you cleared the codes and they came back yes?
Offline javalin
« Reply #4 on: 04 February 2011, 12:46 »
cheaper to shove an new sensor in - check the condition of the wiring first.  Only way to test it properly is to use a o'scope and be able to run the engine/wheels - i.e. rolling road or something.
Have you tried the usual stuff first; clean throttle body, engine/ecu grounds, check for air-leaks, clean/check air filter?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Kyle!
« Reply #5 on: 04 February 2011, 19:19 »
Yea i cleared them finially got it running and it cut out and threw up the same codes, how do i read the codes from the imob box?
dont suppose you know what this box looks like do ya? or if it says anthing in particular on it? ie "immobiliser" lol
ive had the clocks out to clean up all the connections as i read this somewhere, dont recall seeing a box lol
Hi mate
Car is my daily or was lol, how did you go about pairing the two? ive tried re-coding the key via vag-tacho but no joy there?
James
Yes mate done all this and was determined not to post up with this problem lol
