Author Topic: bora sport clocks  (Read 2804 times)
Offline gavgtiturbo
bora sport clocks
« on: 03 February 2011, 18:25 »
hi as above im wanting some bora sport clocks for my mk4 1.8t,ive just been thinking :undecided: are they coded to the car or will i just be able to plug them straight in and they work? any help much appreciated.
Offline Adam
Re: bora sport clocks
« Reply #1 on: 03 February 2011, 18:29 »
Coded and they need to match the immo version of your car.
immo2 will accept immo3 but immo3 will only take another immo3 set.
Down Hill From Here.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 03 February 2011, 18:31 »
+1 on that..
Offline chrisr103
« Reply #3 on: 03 February 2011, 19:21 »
+ 2
What year is your car?
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline gavgtiturbo
« Reply #4 on: 03 February 2011, 20:54 »
+ 2
its a 99 agu
Offline chrisr103
« Reply #5 on: 03 February 2011, 22:00 »
So either immo2 or immo3 will work for you
Offline andc1
« Reply #6 on: 03 February 2011, 22:19 »
i was looking into this, clocks your looking at around £100, coded, £20, i ended up buying oem foils, found some needles and rings from scrappy and fitted, you would not no the differance
http://cgi.ebay.co.uk/VW-MK4-BORA-SPORT-CLOCK-OVERLAY-INSTRUMENT-CLUSTER-FIS-/150549118506?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item230d6d3e2a
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 03 February 2011, 22:21 »
all depends if your icon layout is right though...
Offline bbewekim
« Reply #8 on: 03 February 2011, 22:28 »
these do look smart... they a straight swap on an AGU? wiring wise etc.. do you get all the digital display?
Offline andc1
« Reply #9 on: 03 February 2011, 22:37 »
have a look and see what ones on there are the same as yours, i had to chop mine abit as mine are only 3 lights acroos the centre where as aum have 4, i just cut them off and taped my original to the new!, i was lucky enough to find a passat b5.5 in the scrappies as they share the same needles and rings as anni's
