Author Topic: Power Steering  (Read 1146 times)
Offline puzzled
Power Steering
« on: 03 February 2011, 16:38 »
well its leaking... whats the easiest thing to do (bear in mind not alot of funds) replace the power steering rack or put a standard 1 on... m.o.t on tue...
Offline Simeon
Re: Power Steering
« Reply #1 on: 03 February 2011, 16:52 »
If it's leaking at the rack then probs easiest just to replace. In my experience it's the bottles that crack around the back, causing fluid to run down the lines.
Offline puzzled
Re: Power Steering
« Reply #2 on: 03 February 2011, 16:56 »
you can see the fluid below the boot (pass side) it looks like its rather coming out the boot or the joint ?
the only thing making not want to change to normal is the hassle of trying to sort different pullys and belts out..
