Author Topic: Hard to start when hot  (Read 10903 times)
Offline storky
« on: 03 February 2011, 16:35 »
Hi all,
Couldnt find an answer in the search section. Got a 1991 8v GTi. Starts fine from cold but takes ages to start when engine is warm. It did this on both the old and new engine.
Any ideas??
Thanks
Jon
Offline the_stink
  • A3 140 TDI
Re: Hard to start when hot
« Reply #1 on: 03 February 2011, 16:36 »
Starter motor?
mine did a similar thing would start from cold but then the starter motor would seize when hot had to replace it with a new bosch one and never had any issues since  :smiley:
Offline mk2bal
« Reply #2 on: 03 February 2011, 16:55 »
Leaking injector/injectors?
Could be flooding the engine if they weep or drip..
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 03 February 2011, 17:25 »
the above sounds unlikely to me it happens on a lot of cars and tends to be start motors wearing out..  not saying the injectors cant leak..
Offline storky
« Reply #4 on: 03 February 2011, 17:49 »
Ok thanks guys. Not a huge problem, just seems to take a while to fire when hot. A little dab of the throttle usually helps it?
Offline emery1990
« Reply #5 on: 03 February 2011, 18:38 »
Mine done it all the time! used to get out at petrol stations and whack my starter with my wheel wrench! was a bit embarrassing!
Offline mk2bal
« Reply #6 on: 04 February 2011, 13:21 »
Tech- it depends what he means by hard 2 start!! Slow turning starter when hot-yeah fair enuff prob the starter, but if it spins at the same speed but won't start then I'd say its the injectors/fuelling issues..
Offline Mr Blue
« Reply #7 on: 04 February 2011, 15:17 »
First start with the a new blue coolant temp sensor. Approx £15 from VW.
Offline Alec
« Reply #8 on: 05 February 2011, 03:35 »
Yep, mine was the same at the same time as my idle issues started. Would start turn of the key when cold and once warm if I stopped at the shops and went to start it again it was cranking just fine but took ages to start again, when it did cough a bit I had to coax it into life with dabs of throttle. Revs would usually hunt up to about 1500 - 2000rpm when it got running again aswell until being revved or driven through first gear.
Replacing the blue temp sensor for a genuine VAG item did seem to cure the hot start problem, but not the idle issue  :sad:
Offline mr mk2
« Reply #9 on: 06 February 2011, 09:21 »
i had a similar problem with my first mk2 if i remember rightly it was a fuel problem too lean
