ok driving my valver quite hard the other day. (maybe revved it up to the red
) and i felt something go on it. now it wont idle and is just revving on its own - same as a problem i had about 6mths ago. There is also a strong smell of oil which wasnt there before
I have checked all the usual
1. vacuum/oil breather pipes
2. ecu/fuel pump relays
3. i have a new crank sensor/temp sensor in and had a full service done around a month ago.
any ideas?? also i cannot re-set my mfa readings and it will no longer let me connect to VAGCOM (only ecu)
is my ECU knackered?
