Author Topic: Leak!!!  (Read 1110 times)
Offline Wisey
Leak!!!
« on: 03 February 2011, 00:02 »
Started getting a really bad leak in the passenger footwell lately, after any kind of rain. Got a little leak last year when it was heavy rain and the car was sat but it just made the carpet a bit damp. But now in heavy ran there is a big puddle in the passengers footwell its like a swimming pool  :cry: :laugh:
But I cant work out where its coming from at all...... Because its just the half at the seat that gets wet! There is not wet-ness or damp at the firewall side of the footwell or in the rear or the drivers side at all. And had a look at the pollen filter etc and it looks all fine and there it no holes in the door seal that i could see either  :undecided: But when I was driving today am sure I seen a drop come from the top of the passengers door but it could have just been a drip down the outside off the window :laugh:
So do I just need a new door seal or does anyone have any ideas at all ?
And its a 3 door if that makes any difference  :smiley:
Offline The Dave
Re: Leak!!!
« Reply #1 on: 03 February 2011, 00:35 »
Have you got a sunroof? There are some "nipples"  :shocked: half way up the door frames as you open the door which clog up with sh!t and can cause issues, you have to squeeze them  :laugh: and the gunk should come out then they can drain properly :)
Offline daz veedub
  • Operation 1.8t bolf
Re: Leak!!!
« Reply #2 on: 03 February 2011, 01:01 »
i cut the end of the nipples in door let water through better, also check the pipes of the sunroof drains havent come off
Offline T_J_G
Re: Leak!!!
« Reply #3 on: 03 February 2011, 08:37 »
Pollen filter, do a search.
Offline mcgee9t2
Re: Leak!!!
« Reply #4 on: 03 February 2011, 11:48 »
Read his first post. He said he's checked the pollen filter.
I agree with above, proberbly sun roof
If not (providing its cheep, don't know how much it costs to do...) ide get the door seals changed see if it makes a difference.
Offline Wisey
Re: Leak!!!
« Reply #5 on: 03 February 2011, 15:19 »
Cheers guys I'll just the nipple thing a try  :tongue:  :laugh:
My car is a non sunroof to so wont be anything to do with that  :grin:
If the nipple thing doesn't work I'll just need to sit in the car for a bit the next time if raining heavy and see if I can see where the water is coming in   :laugh:
Offline Mr_Orange
Re: Leak!!!
« Reply #6 on: 03 February 2011, 17:04 »
Go down the local jet wash with a buddy and sit in the car while they blast the heck out of it, or try the same at home with a bucket of water down around the window seals and scuttle panel etc.
In that location I think the sensible money's on a leak around the pollen filter....
No sunroof, no nipples.
The seal at the bottom of the door can leak too.
Both covered in this great link I bookmarked:
http://www.seatcupra.net/forums/showthread.php?t=44216
Build thread clicky
