Author Topic: flasher unit  (Read 2106 times)
Offline derek
flasher unit
« on: 30 August 2003, 17:40 »
I've got a problem with the flasher unit in my 8v mk3 gti.  the fault was intermitant but has since become constant.  the switch at first was buzzing and making a horrid sound, so i changed it since then the switch constantly clicks, the indicators and hazards all work ok its just annoying any ideas what i can do i've taken the steering colum apart and put it all back after a clean buty no joy.  also the factory fitted alarm is a bit of a bugger to set could the problems be linked?
cheers any help would be welcome.
golfvr6
Re:flasher unit
« Reply #1 on: 03 September 2003, 18:45 »
Take it to an alarm specialist, they should be able to help.
Offline modulater
Re:flasher unit
« Reply #2 on: 05 September 2003, 00:19 »
What switch are you talking about?
If its the indicator switch then it needs looking at and is probably knackered, I suspect you mean the relay is buzzing which means it isnt throwing properly, this could be down to it being faulty, a problem in the circuit or even a bad earth.
The relay will click on and off and some are louder than others
