Author Topic: hot helppp  (Read 13123 times)
Offline simbo
hot helppp
« on: 29 May 2003, 16:28 »
hello, have a problem with over heating!!! bottom hose on the radiator is cold while top hose is hot? radiator does not seem to be that hot either,any ideas why this might be? also red light flashing on temperture gauge flashes when started could this all be linked,
thanx
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline richandhazel
Re: hot helppp
« Reply #1 on: 29 May 2003, 16:54 »
Sounds like your thermostat isn't opening.
When you start the car from cold, the thermostat is shut so as to not allow coolant to circulate through the radiator. This helps to get the coolant to operating temp as quickly as possible. Once you reach operating temp, thermostat should open to allow flow through the radiator and provide cooling........this doesn't appear to be happening in your case.
Thermostats are inexpensive and replacement and testing is covered in the Haynes manual.
If you haven't got a Haynes.....let me know, I'll post some info for you.
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline VWnut
Re: hot helppp
« Reply #2 on: 29 May 2003, 17:51 »
Sounds about right. To test it put some cold water in a saucepan with the thermostat then boil it then cool it back down. The thermostat should open and close......
Offline simbo
Re: hot helppp
« Reply #3 on: 29 May 2003, 17:57 »
thanks i'll try that  :D
