Golf mk3
hardmonkeys
starter motor stalls. (i think)
Topic: starter motor stalls. (i think) (Read 2067 times)
stainesy
im not a master debater but i'm a cunning linguist
02 February 2011, 17:01 »
ok since my car cut out last week and had to get recovery truck home i have put new coil on and all seems ok.
but if the car is left over night or for the day when i go to start it when i first turn the key it clicks and its almost as if the starter motor starts then stops a few times then it turns over fine.
its not just a click i feel the donk as it tries to turn the engine but the engine dont turn but then it does and all is ok.
any ideas?
Seanl
Re: starter motor stalls. (i think)
02 February 2011, 17:40 »
Sounds like a duff battery to me
Rare OEM
GTI forum regular
rare part hunter
02 February 2011, 19:53 »
Ignition switch?
Black magic mk3 golf VR6
Audi A4 Avant Black edition
Wayne
Sir Postalot
02 February 2011, 23:55 »
Battery voltage dropping, might be time for a new one.
Khare
Serious forum addict
The bear that khares
03 February 2011, 00:34 »
I had the same problem, not the noise though, just the lazy starter motor.
Stuck a new one on ,well used, and it sorted it out.
tshirt2k
Been there...Done that...
03 February 2011, 06:42 »
Sounds like a sticking solenoid. Starter may just pack up soon.
Mk3 ABF 16V
T
Megasquirt V3
stainesy
Reply #6 on:
03 February 2011, 10:24 »
Oh great. How easy job to change?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #7 on:
03 February 2011, 10:47 »
dead easy, 3 bolts hold starter to the car
put a jack under the engine, undo the top bolt/nut holding the bracket to the front engien mount. jack engine till it lifts off the mount, then undo all the nuts & bolts holding the starter and wiring to to the car, then swap it over
javalin
Reply #8 on:
03 February 2011, 10:56 »
disconnect battery neg cable first! - starter is always live...!
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
stainesy
Reply #9 on:
03 February 2011, 11:08 »
Ok great cheers may look for used one does it have to be for an 8v gti or are all mk3 golf starter motors the same?
Golf mk3
hardmonkeys
