Author Topic: front bushes questions  (Read 1783 times)
Offline javalin
« on: 02 February 2011, 10:11 »
Hello!
My bushes are screwed, lots of play when you waggle the wheel  :sad:  Its a GTI.
So after some advice (obviously they need changing) but I can either:
1)  Replace with poly bushes
    Whats peoples thoughts and experiences with poly-bushes?  Any recommendations?
    Anybody recommend a tool for re-fitting them?
2)  Replace the lower arm with pre-fitted bushes.
     http://www.vwspares.co.uk/g3suspension.php
     I assume from http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/polybushings/index.htm that I can just mark, unbolt and rebolt?
Cheers,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
  • The bear that khares
Re: front bushes questions
« Reply #1 on: 02 February 2011, 11:17 »
When I fitted polybushes I was very happy with it, it tightened the front end a massive amount.
They're also a doddle to fit!  :smiley:
« Reply #2 on: 02 February 2011, 11:18 »
I would go for Poly bushes, will help tighten the front end.
Offline javalin
« Reply #3 on: 02 February 2011, 11:33 »
thanks both, any recommendations as to make, and a pressing tool that doesn't cost £££
James
Offline Khare
« Reply #4 on: 02 February 2011, 11:35 »
They don't need to be pressed in. I've got floflex at the front
http://www.floflex.co.uk/product_info.php?cPath=28_91&products_id=227
Says they're for mk2, but they fit the mk3 as it's the same wishbone.
« Reply #5 on: 02 February 2011, 11:39 »
Don't forget to get the track / camber checked afterwards.
Offline javalin
« Reply #6 on: 02 February 2011, 11:45 »
so what do you use, just a vice/g-clamp to push the bushes into the arm....?
James
Offline Khare
« Reply #7 on: 02 February 2011, 11:54 »
Nope, some copper grease and they slip in  :smiley:
Offline javalin
« Reply #8 on: 02 February 2011, 12:00 »
oh, ok.  Easy then.  Ta, will get some ordered.
J
Offline Khare
« Reply #9 on: 02 February 2011, 12:12 »
Make sure you put the bush in first then slip the aluminium tube in to tighten the bush up, otherwise you will need a press and you may break the bush.  :smiley:
