Author Topic: Strange engine noise  (Read 1343 times)
Offline paul69
« on: 02 February 2011, 00:00 »
When driving my digi at 70mph+, the engine makes a strange noise. The noise seems to go up and down in waves rather than a continuous drone. In the last 12 months the car has had new dizzy cap, rotor arm, spark plugs, ht leads and had an oil and coolant change. I think it needs to be set up properly as in rubjonny's guide, which will be done as soon as I can afford the equipment, but I would like to know if it  is something else causing this so I can look at that in the meantime.
Offline rob.043
Re: Strange engine noise
« Reply #1 on: 02 February 2011, 09:05 »
its definatley from the engine? So does the noise change if your in 4th at 70 rather than 5th or neutral?    Its not a wheel bearing drone?
Offline Alec
« Reply #2 on: 02 February 2011, 09:59 »
Like Rob said, is it a droning noise? Tapping noise? Rattling?
What rpm does it make the noise and does it do it at the same rpm in every gear or on in top at 70?
Offline paul69
« Reply #3 on: 02 February 2011, 12:18 »
I have only noticed it in top gear at about 70+, then goes when speed drops. Droning sort of noise but in up and down waves which I haven't heard before.
Offline rob.043
« Reply #4 on: 02 February 2011, 17:39 »
'sounds' like it could be a wheel bearing. jack up the wheels individually and give em a wiggle.
if not, I duno!  :undecided:
Offline paul69
« Reply #5 on: 02 February 2011, 18:59 »
OK, I will check that out the weekend then. Thanks.
