Author Topic: door and boot seal  (Read 1401 times)
Offline emery1990
door and boot seal
« on: 01 February 2011, 19:25 »
If theres water on the seals of the door and boot, does this mean that the seals have gone and need replacing.
Offline Mr Blue
Re: door and boot seal
« Reply #1 on: 01 February 2011, 20:01 »
could just get away with adjusting the door and boot?
twist the rubber stoppers in on either side of the boot door
move the door striker pin inwards.- adjusted with a spanner
« Reply #2 on: 02 February 2011, 13:48 »
if theres water on top of the door seals, its the gutter strips that have gone. at the boot it could be the seals have shrunk, but as long as the water isnt getting past them then its fine
Offline emery1990
« Reply #3 on: 02 February 2011, 17:00 »
Thanks, yer the water getting by lol, in the boot its bad, wet window but I think as I've got a rust hole waters getting in through there but thought maybe the seal was letting by aswell. in the front its pretty wet too on passenger floor mat but noticed that rubber disc seal is missing in my engine bay, so most probably that ? as sunroof seems fine and not blocked.
Ill get the rubber discs and sort the rust out before getting new seals
Offline Mr Blue
« Reply #4 on: 02 February 2011, 19:37 »
also check the rear light seals. :smiley:
Offline emery1990
« Reply #5 on: 02 February 2011, 20:08 »
I have done and they seem ok, couldnt see anywhere it would leak through  :undecided:
Offline tony_ack
« Reply #6 on: 03 February 2011, 20:52 »
Could also be a leaky weather seal in the door itself, expecially if the doorcards are wet.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
