Author Topic: Dead spot around 1800 rpm?  (Read 1079 times)
Offline dr. benway
« on: 01 February 2011, 14:48 »
I've had a long-standing problem with my AUM where occasionally when accelerating in 1st I'll get a sudden power drop at about 1500-1800rpm. How hard the acceleration is doesn't seem to affect it but it's certainly more noticeable under hard acceleration. I thought it might be the MAF but it's still doing it every so often after replacing that.
It's almost as if the ECU is dropping the power but I don't get the traction control light. No fault codes. Anyone any ideas what might be causing it?
Offline p11jon
Re: Dead spot around 1800 rpm?
« Reply #1 on: 01 February 2011, 16:18 »
misterious banging from underneath now powerloss? you ent having much in the way of luck fella are u.   :undecided:
Offline Mr_Orange
« Reply #2 on: 01 February 2011, 17:10 »
Our AUM used to suffer with this occasionally.  What cured it was hard to pin down as I noticed it had gone after fixing and replacing quite a few different things.  My money would be on a small boost leak I found at the turbo elbow outlet pipe (though yours could be anywhere on charge side).  Have you checked for fault codes?  17705........?  :sick:
Build thread clicky
Offline richw911
« Reply #3 on: 01 February 2011, 17:15 »
As said boost leak  :undecided: Split pipe somewhere  :undecided:
TB clean?
Offline dr. benway
« Reply #4 on: 02 February 2011, 09:44 »
Ha, it never rains... this is after the other problem I had (must update the thread) with the secondary air pump and hoses  :cry:
As it happens these two things aren't really that much of a worry; hardly carry passengers and the power loss is reasonably rare, and only in first. Other than that it's running lovely  :grin:
The TB was recently cleaned out (< 1 yr), so I'll have a check over the turbo piping. I had 17705 a while back but that seemed to be to do with the secondary air that's been recently fixed and hasn't come back since.
Cheers gents.
