Author Topic: FUEL PRESURE REGULATOR  (Read 760 times)
Offline dumbnut
« on: 31 January 2011, 23:06 »
Still trying to get to the bottom of my golf stuttering when pressing the pedal lightly around 2000rpm. after reading someones post they changed the fuel reg and cured there problem. can anyone tell me where to find it, pic if poss would be most greatful.
Offline HeavySmoker
  • DUB and BUD
Re: FUEL PRESURE REGULATOR
« Reply #1 on: 01 February 2011, 00:03 »
Isnt the regulator inside the fuel pump?
« Reply #2 on: 01 February 2011, 00:04 »
Depends on engine but I believe it is on the end of the fuel rail
Offline javalin
« Reply #3 on: 01 February 2011, 10:59 »
on the 2l 8v AGG at least its on the end of the fuel rail.  Suspect that same for the GTI's and VR6's.
Easy to change - but expensive from VW - £60 ish.   Worth checking the hose to the throttle-body is OK first.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #4 on: 02 February 2011, 13:28 »
put a drop of machine oil down the vac port on it, been known to fix a sticky fpr. certainly cant hurt and free to try
