Author Topic: vagcom lead wanted  (Read 2285 times)
Offline mark_gti
Re: vagcom lead wanted
« Reply #10 on: 31 January 2011, 23:44 »
iv got an airbag fault and would like to c if i can get miles to empty
Offline chrisr103
« Reply #11 on: 01 February 2011, 07:09 »
You need Vagtacho for miles to empty
<a href="http://giffgaff.com/orders/affiliate/chrisr45" target="_blank"><img src="http://giffgaff.com/banner/01_80x15.png" width="80" height="15" alt="Get a free giffgaff Sim" /></a>
Offline Rhyso
« Reply #12 on: 01 February 2011, 08:04 »
if your on windows vista you have to run vagcom as an administrator (right click) and it works!
i am running vista, and set as administrator but it comes up as shareware version with limited access... what do i need to do buddy?
Buy the full version......or find ways around it
« Last Edit: 01 February 2011, 08:44 by Rhyso »
Offline rockmonkey69
« Reply #13 on: 01 February 2011, 09:02 »
It's awkward but I never had any problems with these third party vag-com cables on windows vista a few years ago or windows 7 and this was with vag-com and now vcds lite. Never had to right click and run as admin either.
Offline mark_gti
« Reply #14 on: 01 February 2011, 10:15 »
im stumped all my other obd software works just cant get this 1 to which i need for the air bags
Offline mikemk4gti
« Reply #15 on: 01 February 2011, 12:28 »
There's normally a driver for the cable on the disk that comes with the software. I plugged the lead in then told it where the drivers were and it installed them automatically.
 Then, start vagcom as an administrator and on the settings try different com ports till it finds it, mine is always com3 then you can save and it should work.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline mark_gti
« Reply #16 on: 01 February 2011, 16:29 »
ok does it need to be pluged in to car to reconize interface or not
Offline mikemk4gti
« Reply #17 on: 01 February 2011, 20:01 »
another thing, if youre on a 64 bit operating system you need different drivers!
Offline mark_gti
« Reply #18 on: 02 February 2011, 18:27 »
im on 32 bit and tryed every thing just wish i could aford a proper lead that would just work when ya plug it in
