Author Topic: Power loss  (Read 2333 times)
Offline Atom
Power loss
« on: 29 August 2003, 12:15 »
Hello all
I'm new to the forum and I'm jumping straight in with a problem I hope someone can help me with.
I own a 1988 8v GTi (PB, Digifant). However after some engine damage I replaced the Head and Block with a 1985 8v engine (K-jetronic?). It did run really well, quicker than the orginal. But now it sounds fine, no obvious mis fire, but it has a serious lack of get up and go.
I have cleaned and replaced all the filters, spark plugs checked and it has brand new injectors.
Any help will be much appreiciated
golfvr6
Re:Power loss
« Reply #1 on: 29 August 2003, 13:37 »
Check ignition timing and fuel mixture.
Offline mk1
Re:Power loss
« Reply #2 on: 29 August 2003, 20:38 »
PB with digifant, dont  they use a knock sensor?. Are you using the PB distributor?. Steve.
