Author Topic: Mk3 golf GTI 8V non start  (Read 7999 times)
Offline pugoff
Re: Mk3 golf GTI 8V non start
« Reply #20 on: 31 January 2011, 12:02 »
oh.  Fuel leak?  If it cranks fast - i.e. sounds like it just spins - sounds like it has no compression.  Can you compression test it?
nah, only smells of fuel if its turned over, im guessing the unburnt fuel... and as for compression test, the garage claim to have done that when they had it. I will see if i can hunt down some1 with compression tester and check for myself.
« Reply #21 on: 31 January 2011, 14:33 »
yeah if you swap ecu it can be recoded with vag-com easily. its if you want another key that things get tricky
Offline VR6_Wherry
« Reply #22 on: 31 January 2011, 14:45 »
Try replacing the ignition switch.
Mine used to fire up then die straight away!
Offline javalin
« Reply #23 on: 31 January 2011, 14:48 »
apart from the keys, what is there to re-code if its the same type (engine) ECU?
if his is cranking and sparking its not the switch - its not firing at all from the sounds of it.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline pugoff
« Reply #24 on: 31 January 2011, 15:16 »
James
im not sure, i believe you are coding the ECU so it has same "code" as key, but i might be wrong  :undecided:
and as for switch, it had been mentioned but due to the fact its sparking and fueling and turning over i didnt see how the switch could be an issue  :undecided:
Offline VR6_Wherry
« Reply #25 on: 31 January 2011, 15:24 »
James
Well, sometimes my car wouldn't start at all..then sometimes it would just cut out when i was driving and wouldn't start..one Ignition Switch later and all was good.
Offline pugoff
« Reply #26 on: 31 January 2011, 15:36 »
can someone explain/show me where the ignition switch is, and how to change it.
thanks
« Reply #27 on: 31 January 2011, 15:37 »
the immobiliser box :)
the keys are coded to the immobiliser box, and the immobiliser box is coded to the ecu. if you swap ecu, you can match it to the old immob box easily with vag com, though it needs to be a 'registered' copy. if you change the box or keys things get tricky, you need vag-tacho to get the skc code, and you can only get that if you have matched key in the ignition.
if you get a matched immob box and chip you can fit these to your car and old key, then do the ecu recode thing, but we are digressing from the thread a bit now ;)
Offline javalin
« Reply #28 on: 31 January 2011, 15:49 »
oh ok - but good information.  The immob box is in the dash isn't it?
Offline danmusic24
« Reply #29 on: 31 January 2011, 17:21 »
