Author Topic: rear bumper  (Read 3259 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
rear bumper
« on: 27 February 2005, 09:49 »
ok how do i remove the rear bumper as i want to take the towbar off
is it tricky or easy
cheers
Offline Mr Blue
Re: rear bumper
« Reply #1 on: 27 February 2005, 12:12 »
if i remember correctly you unbolt the two bolts under the car. then there are two screws at the bottom corners of the bumper.
should slide out.
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
Re: rear bumper
« Reply #2 on: 27 February 2005, 12:34 »
This is a doddle if the bolts are not seized..
There will be three small bolts on the underside of the bumper two near the bottom of the back arches and one around the middle of the rear bumper remove these first
then there are two each side holding the bumper in place bolt from underneath. these are the hard ones to remove as they become seized up.
get these opf and all you do is slide the bumped backwards off the slide mounts
 :wink:
Offline ...joe
Re: rear bumper
« Reply #3 on: 01 March 2005, 17:34 »
are there? i don't think i've ever undone these? how odd...............
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline ...joe
Re: rear bumper
« Reply #4 on: 01 March 2005, 17:34 »
sorry, confused by this..... not being sarcastic! i honestly don't know what bolts your talking about?
Judderi
Re: rear bumper
« Reply #5 on: 02 March 2005, 08:33 »
There just little self tappers holding the plastic in place. Not essential and probably missing if youve never noticed them. But yes i agree with you all its an easy job. The only trouble i had was moving the exhaust out of the way to get at the 2 bolts on one side as my exhaust silencer was huge!
Re: rear bumper
« Reply #6 on: 02 March 2005, 13:19 »
To take the bumper off there are just 4 bolts, look underneath and you'll see the 2 big metal supports either side and the bolts holding them on.  Unfortunately the nuts are square jobbies that just sit in a square hole if you get me, so they can pup out when you try to undo the bolts.  Takes a bit of a fiddle to get them back into the slots, but shouldn't take more than 30 minutes to swap the bumper if the bolts arn't totally siezed.
Judderi
Re: rear bumper
« Reply #7 on: 02 March 2005, 13:54 »
Mine was held on with your average bolt, not square jobbies. i just used a socket set to remove them. Might be different on different years.
Re: rear bumper
« Reply #8 on: 02 March 2005, 14:15 »
Yeah the bolts are standard, I mean they are screwed into nuts that sit in a square hole, if they pop out the bolt will just turn without loosening if you get me.
Judderi
Re: rear bumper
« Reply #9 on: 02 March 2005, 14:24 »
Ah i see what you mean now. I must have got lucky cos i didnt have this problem.
