Author Topic: Down AND Out???  (Read 1326 times)
Offline mikemk4gti
Down AND Out???
« on: 30 January 2011, 19:59 »
 Right, I'm trying to get a decent stance on my car, I've got 18's on with 20mm spacers on the back and the wheels slightly protrudes the arch, so I guess that's the OUT bit, but if I want to go lower the wheel will be rubbing the arch, unless I remove the spacers (or get a bit of stretch?)
 So, what do you guys do???
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline daz veedub
  • Operation 1.8t bolf
Re: Down AND Out???
« Reply #1 on: 30 January 2011, 20:13 »
ive caught the paint abit on o/s rear arch abit so  iam thinking stretch tyre too as the 20mm stance is sweet
Offline Grand Master Patch
Re: Down AND Out???
« Reply #2 on: 30 January 2011, 20:29 »
It's a hard look to achieve with wheels of the same width but can be done,the problem is that the smallest tyre in 18inch is a 205 and they don't come cheap,well over £100 each iirc.
Offline mikemk4gti
Re: Down AND Out???
« Reply #3 on: 30 January 2011, 21:25 »
If I had 9j on the back it's only the same as 8j with a 1" spacer isn't it? They'll still poke the same.
I'll have to wind them down a bit more I think and experiment!
Re: Down AND Out???
« Reply #4 on: 30 January 2011, 21:31 »
No,they would poke the same but you can stretch a tyre more on a 9J than you can with an 8J,this stretch allows you to go lower without rubbing.
