Author Topic: Coolant hole on side of engine? No idea!!!  (Read 3119 times)
Offline bmouthboyo
Re: Coolant hole on side of engine? No idea!!!
« Reply #10 on: 31 January 2011, 13:25 »
but there was hardly any coolant in there due to leak.
Do these pop out when head gasket goes?
Offline Simeon
« Reply #11 on: 31 January 2011, 15:56 »
As stated previously, two most likely reasons are;
System over pressurising due to possible gasket issues.
Lack of antifreeze, they tend to pop if the water freezes.
Offline bmouthboyo
« Reply #12 on: 31 January 2011, 16:55 »
Ok thanks for all the help so far guys
I did a compression test about a year and a half ago, I think just before I had the head removed to have a bolt helicoiled. The head was skimmed so I assume would increase pressure slightly.
I couldn't get engine warm as it wont start at moment :(
Results from year and half ago:                                    143 - 151 - 151 - 153
Results from today (may have had little fuel in cylinder):  154 - 192 - 170 - 180
2nd time:        130 - 160 - 140 - 172
3rd time:        150 - 154 - 140 - 170
So cylinder one seems to generally be lower than the others. The first test I assume was higher due to possibly some fuel being in cylinders by the end they looked dry when I shone torch into them.
I followed the instruction on back of my pressure gauge. Spark plugs removed, dry with throttle open.
So does this point to the core plug being blown due to head gasket?
« Last Edit: 31 January 2011, 17:27 by bmouthboyo »
Offline danny_p
« Reply #13 on: 31 January 2011, 18:34 »
with the amount of problems you have had with this engine, have you though about just swaping in another, theose compression test results are high enough for it to run but there not brillian't  and are nearly just in spec  but TBH there crap.
100 is the bare minumum to run,    150 is manageabole but it means the engine is pritty near end of life.   a good strong engine with a good starter should do 190psi  even when cold,  often top 200psi  when hot.
it chould be possible that your cam timeing is out
all the VW's have gone bar 1.
Offline bmouthboyo
« Reply #14 on: 31 January 2011, 22:24 »
Hi danny,
Unfortunately I dont have the money, or space to do a full engine swap. If it is inevitable than I'll learn my way about this engine and if the time comes maybe then have to do so. Although it is a Gti engine it is in a 27 year old 2700Kg camper van, so performance isn't a priority. I just want it running and reliable. It has to be better than the 1.6D it left the factory with lol
On a side note the engine was put into the van back in 94 with only 27000 miles. It now has done 52000 so still pretty young, although neglected. It ran a year ago, so must be life still in her.
Does the compression test clearly indicate a fault? Given it is on a cold engine that has not been run in a long time? Am I flogging a dead horse trying to get it going or could it still prove reliable?
I am thinking I should replace the core plug and if it blows again ill know for sure its head gasket. I will also double check the timing marks as it has had the head removed. I will also do a wet compression test and if that makes no difference at least it will suggest valves.
Offline danny_p
« Reply #15 on: 31 January 2011, 23:00 »
i very much dought the core plug has blown out due to a gasket issue,  pipes tend to split or water tanks vent way before they pop out.
the compression readings do indicate a fault but not a headgasket fault,  a HG fault would likely show as 1 or two cyls reading really low,  all of those readings are low.  i wasent suggesting a full engine conversion just a like for like swap.  as PB engines are worth nothing 2nd hand in my experiance and it may just be easyer quicker and more cost effective than fixing the current one,  not that long ago i tryed to sell a rebuild PB and none even wanted to take it away
Offline bmouthboyo
« Reply #16 on: 01 February 2011, 08:42 »
Thanks Danny, ill keep that in mind.
I wont give up on this (DX) just yet, fingers crossed. I'll replace the core plug and keep on in my other non start thread about engine issues.
Offline danny_p
« Reply #17 on: 01 February 2011, 19:05 »
i'd get it started before bothering with the core plug,   they can idel for 30 secs to minute without coolant and it won't harm them.
check your timeing  fire a f**k load of ether at it and see if it tryes,   if it don't  check ignition timeing and that its actualy sparking the right cyl and try again,  once it's run  bof the coreplug in
