Author Topic: turn of the key  (Read 4443 times)
Offline lord14
turn of the key
« on: 30 January 2011, 15:51 »
i turn the key to start the car up , but all i get is a relay click and nothing happens , any ideas ? was working the otther week
Offline Mrwebster
Re: turn of the key
« Reply #1 on: 30 January 2011, 16:18 »
starter motor,   look on gearbox and gently tap the starter motor with a small hammer, then try,  sometimes they stick.  if it still wont work then put it in second gear and roll it forward a bit, (starter could be jammed in the out position. )
Golf GTI turbo (230hp)  mx5 / eunos roadster 120bhp Reliant rialto modified (49hp)
Offline lord14
Re: turn of the key
« Reply #2 on: 30 January 2011, 16:51 »
ok ill go and give it a go
Offline lord14
Re: turn of the key
« Reply #3 on: 30 January 2011, 16:56 »
nope still no luck , would the relay still click if it was knackered ? i can see it sparking inside as its a white case
Offline lord14
Re: turn of the key
« Reply #4 on: 30 January 2011, 17:28 »
oh yeh it is stuck i had to give it a good wack ,how do i get it unstuck ?
Offline Mrwebster
Re: turn of the key
« Reply #5 on: 30 January 2011, 17:33 »
take it off,    or... leave car in gear, roll it back and forth, (if its still connected to flywheel it will turb with it and hopefully go back in,.  there on like a screw kind of thing that shoots out when it spins,
the solenoid sounds like its activating  but not turning.
try rolling it a few times then turn it over (out of gear obviously lol)
Offline lord14
Re: turn of the key
« Reply #6 on: 30 January 2011, 17:40 »
yeh well its defonately sticking at the minute , ill have to give it ago toommorow once i can get some one to push it with me lol
Offline SoundillusioN
Re: turn of the key
« Reply #7 on: 31 January 2011, 08:51 »
It shouldn't need a proper push, ie. no need to move. just enough to rock it whilst in gear.
Offline lord14
Re: turn of the key
« Reply #8 on: 31 January 2011, 09:56 »
oh right , on the mk1 forum there saying i need a new starter motor
Re: turn of the key
« Reply #9 on: 31 January 2011, 10:35 »
You still may need to but if you haven't managed to rock the car with it in gear then I would try that first to unjam it.
