Apologies for my earlier, rather useless, post! Hangover with no coffee = bad mood
Remove the clocks by popping out the warning light panel:
Next remove the headlight switch (you have to press the side to release it)
Once unclipped you will see a screw:
Undo the screw and use a screw driver to pop off the little blank on the other side of the wheel:
Once these have been undone you can remove the black plastic surround by giving it a good pull:
Undo the screw on either side and the clocks will pivot forwards:
I have no pictures for the next step, but the filter is located under the white plastic strip along the top of the clocks, there should be 5 clips holding this in. You can either do this with the clocks still in the car, but it's probably easier to reach behind them and unplug them. Once unplugged you can just pull them out. Hope that helps
