Author Topic: Outside temp gauge in centre cluster!  (Read 1698 times)
Offline Bakesy
« on: 29 January 2011, 17:43 »
Hi,i have a v6 4motion on a 51 plate and there are only two things that are faulty with it. The first is that the lights on buzzer does not work and the second is that the outside temp gaugue in the centre cluster just shows --:-c  Would the faults be both connected to the door micro switch or would that be the light buzzer alone? I'd be very gratefull for any help on this....cheers Paul
P.S The puddle lights,interior lights and door locks all work ok!
« Last Edit: 29 January 2011, 17:49 by Bakesy »
Offline richw911
Re: Outside temp gauge in centre cluster!
« Reply #1 on: 29 January 2011, 17:56 »
Is the sensor under the front bumper connected?
Offline Bakesy
« Reply #2 on: 29 January 2011, 17:58 »
Yes, in fact i had a new one put on.I've had the car for 18 months and can recall it has once registered a temp of-28 but then went blank again.
Offline jonnyturbo
« Reply #3 on: 29 January 2011, 18:00 »
lights on buzzer cud be door module
Offline richw911
« Reply #4 on: 29 January 2011, 18:02 »
Try doing a cluster output test in vagcom and check for any faults.  :undecided:
Offline Bakesy
« Reply #5 on: 29 January 2011, 18:08 »
Would a test at a dealer be expensive? I wouldn't have clue about prices?
Offline richw911
« Reply #6 on: 29 January 2011, 18:10 »
Where are you based?
Im sure someone on here could help.
Offline Bakesy
« Reply #7 on: 29 January 2011, 18:15 »
Im in Sussex. Be nice to get fixed as its super motor and i appreciate your help!
Paul
Offline richw911
« Reply #8 on: 29 January 2011, 18:18 »
Paul
See here http://www.golfgtiforum.co.uk/index.php?topic=87936.0
Or put a post in the vagcom section  :wink:
Offline Bakesy
« Reply #9 on: 29 January 2011, 18:22 »
Nice one,cheers Rich
