Author Topic: Engine Mounts  (Read 3647 times)
Offline Justins145bhpMK1
Engine Mounts
« on: 29 August 2003, 11:18 »
Hi there, my Mk1 is developing a knock, when you pul off and 'rock' the engine by coming on and off the gas when going along, think its an engine mount . Any other things I should check and also how do I check the engine mounts??? I know the big one at the front is brand new.
golfvr6
Re:Engine Mounts
« Reply #1 on: 29 August 2003, 13:40 »
Put the bonnet up, rev the car on the clutch and drive across a car park while you get a mate to watch the engine. Another thing maybe to look it is the exhaust.
Offline richandhazel
Re:Engine Mounts
« Reply #2 on: 29 August 2003, 17:50 »
That front one that you have replaced, is it adjusted correctly? The primary purpose of that front one is to counter the engine rotation. However I guess its going to struggle to do that if one of your other mounts is completely knackered.........check underneath where the gearbox mount is bolted to the chassis.......I had to change that at the same time as doing my front one.
golfvr6
Re:Engine Mounts
« Reply #3 on: 03 September 2003, 21:09 »
Is there any adjustment??? there wasn't as far as i saw when i did a front mounting on a mk2 16v last year.
Offline mk1
Re:Engine Mounts
« Reply #4 on: 03 September 2003, 22:15 »
The mount has two bolt holes that are slotted, allowing you to adjust the mount up or down. I set mine by pulling the metal part down onto the rubber so that it limits the amount of movement when the engine is pulling. Had no probs with this method. Check the one by the timing belt, when I took my engine out, it was well worn ::). Good luck, Steve.
Re:Engine Mounts
« Reply #5 on: 04 September 2003, 00:20 »
Yep its totally different to a MK2. On a Mk2 that front one is actually a mount, not an anti engine roatation device as it is on a Mk1. Ask MK1_BOY and 87_PROJECT........I nearly dropped a Mk2 engine on my head because I assumed that mount did the same..........duh!!!!!
You never stop learning............
« Last Edit: 04 September 2003, 00:21 by richandhazel »
golfvr6
Re:Engine Mounts
« Reply #6 on: 04 September 2003, 15:22 »
Oh yeah , i think i know what ya mean now. The mk1 is like a big damper thing , same as the scirrocco  :o
Re:Engine Mounts
« Reply #7 on: 04 September 2003, 15:42 »
Thats it, like a rubber doughnut sitting in a cup.
golfvr6
Re:Engine Mounts
« Reply #8 on: 07 September 2003, 14:27 »
Yep, the Audi got a similar thing on it, but its a vibration damper rather than an actual mount.
