Author Topic: Oil temp sensor?  (Read 13954 times)
Offline M
Oil temp sensor?
« on: 30 May 2003, 10:51 »
I drive a 1990 Gti 16v.  My oil temp display is reading - --.  All the other readings seem to be okay.  Does the oil temperature sensor need replacing?  If so where abouts is this located and how much is a new one likely to cost?
Many thanks.
M
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
old_boy
Re: Oil temp sensor?
« Reply #1 on: 30 May 2003, 11:32 »
Hello m
I recently bought a mk2 16v with the same prob.
look behind on the back of the head behind the dizzy and you will see a brass sender and probably a wire swaying around (cant remember what colour but can get back to you) connect it back up like i did and hey presto0oil temp readings
Offline M
« Reply #2 on: 30 May 2003, 16:54 »
I think I've found the brass sender bolted to the back of the head behind the distributer.  There is no wire attached but has what looks like a small disk on the end.  There is also a green wire that has been cut emerging from other wires just behind the distributor.  Would be greatfull if you could let me know the colour of your wire.
M
old_boy
« Reply #3 on: 30 May 2003, 19:19 »
Hello M,
The wire you need to connect up is green and black striped-I'll send you a picture of mine via E-mail (excuse the oil!) hope this helps. :)
Offline M
« Reply #4 on: 31 May 2003, 14:03 »
It sounds like the one that's been cut.  I look forwards to receiving your photo.
Thanks in advance.
M
