Author Topic: changing rear brake line  (Read 767 times)
Offline tg1
« on: 29 January 2011, 14:33 »
alright lads, managed to get the old brakeline apart, but there is some white plastic fixings on the rear axle/arm that hold the brakeline down.
how do you remove these as if there is a screw in it, its corroded to buggery?
Offline houston
Re: changing rear brake line
« Reply #1 on: 29 January 2011, 14:41 »
there just a half circle clip that the brake line push fits into, if your having bother then just snap it and use a p clip to hold the new line
Offline tg1
« Reply #2 on: 29 January 2011, 14:42 »
wicked, i'll go give it a go,
is it really pikey to use cable ties when its goes boobies up?
Offline tg1
« Reply #3 on: 29 January 2011, 15:35 »
it didn't even go wrong -  :grin:
clips didn't brake, and the brakeline for ecp needs some persuading to fit - should of got a oem one  :rolleyes:
