Author Topic: What should I do before a remap  (Read 861 times)
Offline chris_vw_1987
« on: 29 January 2011, 01:31 »
I have a AUM engine, I have already bought a Induction filter.. de cat pipe.. trying to find a 007 forge for the right price.. just wondering if I can installed some of the stage 2 items before a remap... but this depends if anyone here knows if the AUM engine has internals that can handle bigger boost, I know a guy with Cupra R thats remapped to somthing stupid like 275bhp.. is this achievable with my engine?
2001 Volkswagen Golf 1.8t - AUM
Offline James Q
Re: What should I do before a remap
« Reply #1 on: 29 January 2011, 09:20 »
it could be worth upgrading the clutch as ive heard standard gti clutches cant handle the increased tourque and start slipping quickly after a re map. Up graded turbo hoses etc?
Offline bbewekim
« Reply #2 on: 29 January 2011, 10:03 »
If you do it all just go stage 2 :).
Stage one will be fine with all stage 2 mods minus the FPR. So that would be, Intercooler/TIP/DV/turbo back exhaust etc etc... Stage two just pushes the car harder because it can handle it fine with the modifications.
The 1.8t can handle ALOT of power for a 1.8 block, to get over the 250 mark and hit the 300 mark your going to need a turbo upgrade along with a few other things to suit.
I would say its not that expensive to see 240hp out of a 1.8t but anything more than that will require some $$ as even upgrading to K04 turbo etc is going to cost quite a bit on injectors/maf etc where as, do all the necessary mods and have plenty of cool air flowing around the turbo you can achieve 240 IMHO on a k03s.
** if your just going for a stage one... probably save your money on half the mods as their generic maps and wont be taylored to loads of modifications and TBH on a stage one you could generally see more turbo lag running a FMIC.
** clutch wise, get a spec one or g60/vr6 conversion, cheap to do and will handle 300lbs of torque... standard clutches are a bit weak.
« Last Edit: 29 January 2011, 10:06 by bbewekim »
« Reply #3 on: 29 January 2011, 14:44 »
Cheers for the replys guys, so I should be buying a clutch kit soon after a remap.. lovely..
