Author Topic: Oil pressure buzzer  (Read 1841 times)
Offline fastphil
Oil pressure buzzer
« on: 26 February 2005, 13:11 »
I have a 92 gti 8v,when i rev it to 2500rpm the oil warning buzzer sounds with the oil light flashing.I have checked the oil level and its ok,the car has been standing around a bit waiting for its new owner to collect it but i have been starting it up every week to keep things in order
any ideas
cheers
« Last Edit: 26 February 2005, 13:17 by fastphil »
free
Re: Oil pressure buzzer
« Reply #1 on: 26 February 2005, 13:58 »
the pump,
i think it still flash's, go's off, if its low pressure to :undecided:
free
« Reply #2 on: 26 February 2005, 14:01 »
but as you say its been stood a bit, it might be a bit blocked up, try some of that oil cleaner in it, to clean it out maybe that might solve it
Offline chrismk2
  • Mk2 16v
« Reply #3 on: 26 February 2005, 16:14 »
I have just replaced the oil pump for the same symptons and its sorted when i took it off it turned out that it wasnt genuine vag it was a cheap copy and the car runs sweeter and cooler now.....
Offline bosun
« Reply #4 on: 26 February 2005, 17:09 »
These do have 2 oil pressure switches. 1 for tickover/upto 1500 rpm,fits in the head if i remember rightly.
And 1 on top of the oil filter.Oil pressure switches are known to play up on VW`S.
Also cheap oil filters and oil can cause problems.
Do you get any rattles from the engine when the light is on,tappets start rattling when the pressure is low.
Offline fastphil
« Reply #5 on: 27 February 2005, 01:46 »
Yes ..I have noticed that its a bit noisey on the top end since the buzzer has been active
Veedubgt18v
« Reply #6 on: 27 February 2005, 09:23 »
i bet the pick up on your oil pump is partially blocked, try an oil flush and change if that doiesnt work then drop the sump and clean it by hand
Offline fastphil
« Reply #7 on: 27 February 2005, 10:10 »
Yeah your probably right an oil flush will sort it or a sump drop
cheers
Offline fastphil
« Reply #8 on: 07 March 2005, 21:52 »
Bosun ,you were spot on it was the oil pressure sensor on the filter housing.I still dropped the sump though and checked the pickup and the oil pump,all was well down there.still had the same buzzer prob. so I changed that sensor and yeeehaa!!
Thanks to  all for the advice
Fastphil
