Author Topic: Backlit dials GROUP BUY - Please read first post for info.  (Read 14237 times)
Offline tshirt2k
  • Been there...Done that...
Re: Backlit dials. Anyone interested in a GROUP BUY?
« Reply #10 on: 30 January 2011, 18:17 »
It will just be connected to the inverter by plugs. No soldering unless you want to change the colour of the LCD displays. Easy for me, may not be for others.
Mk3 ABF 16VT Megasquirt V3
Offline Deano2711
  • 1992 VR6
Re: Backlit dials. Anyone interested in a Group Buy?
« Reply #11 on: 30 January 2011, 20:10 »
If you read the post it says they will make them in mph. That's the point of the GB. You can't get these anywhere otherwise. The clocks need to come apart. Needles off. New dials fitted and wired in.
It all depends on what you consider worth paying for they're exclusive. As no One else will have them in there car. Plus if you've spent ££££ on engine conversions, wheels etc. It's not that expensive considering only 15 people will initially have them in the country.   :wink:
Quite a statement to make....what makes you think no one outside of this forum has bought this. I would say there are plenty of people in the UK running these.
Offline Jimp
« Reply #12 on: 30 January 2011, 21:33 »
Yeah there are quite a few people running these already, but either way they are sweet bit of kit  :cool:
Not low enough mk5
Not on the road enough mk3
Offline tshirt2k
« Reply #13 on: 30 January 2011, 22:24 »
Because if people were running these. Why would they need 15 people to make them in MPH. They may have a type of backlit dial, maybe s3 or DDI but they are either not available anymore, alot more expensive or only available for certain clocks.
These ones from this company haven't been made in MPH. They need pictures of the clocks to be able to make them. IF they had already done them they would be available on the website.
Offline AndyMk3
« Reply #14 on: 30 January 2011, 23:19 »
I'm in
Offline tshirt2k
« Reply #15 on: 31 January 2011, 08:29 »
People would need to decide if they also wanted a heater panel and flourecent paint etc..
I have started a list here. And MAY do this if it can go smoothly. (A few people can vouch that the last group buy on other "common" forums went smoothly enough).
Probably have to sort designs into 3 most common. And people will need to supply a daylight picture of each clock to send.
I've worked it out and including P&P the cost should come to around £65heater panel £10 and Flourescent paint (to paint needles )£8 extra.
Add names to list including Car, Design, Backlight colour, Rev limit/range, Speed range - Heater panel (Y/N), Flourescent paint(Y/N.Colour).
1.Tshirt2k - 16V, Design 3, white, 7.5k, 0-160mph, N, N
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
« Last Edit: 02 February 2011, 16:17 by tshirt2k »
Offline boola
« Reply #16 on: 31 January 2011, 09:29 »
1.Tshirt2k - 16V, Design 3, white, 8k, 0-160mph, N, N
2. Boola -16v, design 3, blue, 8k, 0-160mph, n, n
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
Offline tshirt2k
« Reply #17 on: 31 January 2011, 09:33 »
16v owners. Sent company a picture of my clocks and they call the rev range 7.5k And its apparently "Rare" to them.  :shocked:
Offline spear
« Reply #18 on: 31 January 2011, 10:05 »
is there an option just to buy the heater dials as I quite like my dials and as far as i know I'm the only person in the world that is only using UV leds to light them  :cool:
PS. they look 15 times better in the flesh
« Last Edit: 31 January 2011, 10:11 by spear »
Offline tshirt2k
« Reply #19 on: 31 January 2011, 11:47 »
No need to go in for the group buy only for the heater panel. You can buy direct from the website. Should work out ~£25 posted. I bought one ages ago from there.
