Author Topic: Pinging when hot  (Read 3639 times)
Offline set
Pinging when hot
« on: 29 August 2003, 01:17 »
Hi
I am a new MK2 GTI 8V owner (bought 2 days ago). Car has done 213000km. The engine pings under slight load above 3000rpm but only when hot. Does anyone know what might cause this?
Thanks
golfvr6
Re:Pinging when hot
« Reply #1 on: 29 August 2003, 13:38 »
Do you mean pinks?
golfvr6
Re:Pinging when hot
« Reply #2 on: 29 August 2003, 13:57 »
If you do mean pinking then is your car a k-jet or a digifant?
Offline richandhazel
Re:Pinging when hot
« Reply #3 on: 29 August 2003, 17:55 »
Assuming its a k-jet, you need to retard the ignition timing. You could try using Shell Optimax, the higher octane will help.
golfvr6
Re:Pinging when hot
« Reply #4 on: 31 August 2003, 11:42 »
And if it a digifants its probably a faulty or loose knock sensor.
Offline set
Re:Pinging when hot
« Reply #5 on: 04 September 2003, 04:34 »
It is Digifant. The previous owner just did a head gasket replacement on it and it has been suggested to me that they might have put the timing belt on incorrectly. Is this possible? Is there a way to check without a timing light?
Thanks
Re:Pinging when hot
« Reply #6 on: 04 September 2003, 08:16 »
It could well be the timing belt.
You don't need a strobe to check that (strobe is for your ignition timing). If you look in your Haynes manual it should give you a procedure somewhere for getting your engine to TDC and checking your static timing i.e
crankshaft pulley mark is aligned with the arrow on the lower cam belt cover, camshaft pulley mark is aligned with the top of the head etc.
Failing that try 'golfvr6' suggestion with the knock sensor.
« Last Edit: 04 September 2003, 08:17 by richandhazel »
golfvr6
Re:Pinging when hot
« Reply #7 on: 04 September 2003, 15:14 »
It probably is the timing, as rich said checked the static timing at TDC, you be amazed how many people f**k it up.
