Author Topic: Ebc green stuff Vs Black diamond  (Read 10471 times)
Offline Khare
  • The bear that khares
Re: Ebc green stuff Vs Black diamond
« Reply #30 on: 28 January 2011, 00:17 »
So these are bloody cheap then?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280617514953&ssPageName=STRK:MEWAX:IT
Blimey, if that is genuine then I'll be buying a set straight away!
Looks like they are 288mm spec, going by engine and years
That's what I thought, it says they are for Lucas calipers....Can't remember which ones the lucas were, 280 or 288?
« Reply #31 on: 28 January 2011, 11:08 »
they're listed to fit golf G60, so they're 280s. also from the pic you can see they're for 280, but not a good idea to trust the piccy alone. as long as the fitting list is correct though, then they're for pre-96 280mm setup :)
Offline Khare
« Reply #32 on: 28 January 2011, 18:36 »
This is the reply I got from them.
Quote
Hi, yes it's a set of four to do both sides. These will fit your vehicle, although yours may have warning wires fitted which may need either looping or splitting as these are not listed as coming with them (many fast road pads don't use the wires). Hope that helps. Cheers
Will let you guys know how they fit the 288 calipers  :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #33 on: 28 January 2011, 20:04 »
ah right ok, fingers crossed then.
Offline stow1985
  • 'when im cleaning winders'
« Reply #34 on: 28 January 2011, 20:19 »
Ferodo pads are expensive last time I looked, I think about £80 for a front set.
best get saving then  :shocked:
Offline Khare
« Reply #35 on: 28 January 2011, 20:47 »
Dude, the ebay link posted one page back. The mintex M1144 are equal to the Ferodo DS2500 and for some reason they're up for £40 posted!
Offline Paul86S2
« Reply #36 on: 29 January 2011, 00:15 »
Those pads listed will definitely not fit the 288mm brake set up.
The 288mm brake calipers are ATE.
The code for the mintex 288mm pads is MDB1741 followed by the pad compound code.
If the fitment chart also includes Mk11's they not be the 288mm ones.
Paul
« Reply #37 on: 29 January 2011, 00:27 »
Yeah that's also confusing me but for some reason it lists the late 16v mk3's - Odd  :huh:
Offline Khare
« Reply #38 on: 29 January 2011, 00:56 »
Yeah  :undecided:
Well I've just sent the seller another email.
Quote
I've just had confirmed that these pads that you said will fit my 1997 16v 288mm brakes, in fact won't fit. The part number for the mintex pads for the 288mm brakes is in fact MDB1741 followed by the pad compound code, and the 288mm calipers are ATE not Lucas.
Also, I was told that the listing includes Mk2 brakes, which none have 288mm (G60 has the largest, 280mm).
Could I please have a full refund if that information is in fact trust, otherwise I have no use for these pads.
Let's see what he replies with  :undecided:
Offline Paul86S2
« Reply #39 on: 29 January 2011, 11:34 »
These are the right ones for the 288mm brake set up
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230293001874&ssPageName=STRK:MEWAX:IT
He will sell them for £40 plus postage if you make an offer.
Not listed for the Golf but they are the right ones.
Paul
