Author Topic: Temperature light  (Read 2447 times)
Offline Ardz83
Temperature light
« on: 26 January 2011, 18:25 »
I have recently had a problem with my dash light flashing at me after 2 miles of driving. The thing is the gauge is fine and the fan cuts in.
Any ideas?
thanks in advance :smiley:
Offline swampy50
Re: Temperature light
« Reply #1 on: 26 January 2011, 19:10 »
Low coolant level ?
« Reply #2 on: 26 January 2011, 20:30 »
Faulty sensor
« Reply #3 on: 27 January 2011, 10:31 »
check coolant level, if ok bridge pins on level sensor. if problem solved youi need a new one. if its pre-90 level sensor unscrews, if post 90 need to change whole tank
Offline Ardz83
« Reply #4 on: 27 January 2011, 17:10 »
No the level is fine and tried unplugging all the relivent sensor plugs,nothing happened still the same but if i turn the car off then on again its fine.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 27 January 2011, 22:33 »
chaffed wire loosing and finding contact ??
Offline sprout99
« Reply #6 on: 28 January 2011, 07:07 »
mine does this. Had new bottle and cap and various new sensors
even tried replacing part of the wiring and it still does it
not every time but usually after a bit of flogging.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 28 January 2011, 10:39 »
Mine did this a couple of times and at first I thought it was due to me putting the key in the ignition and starting the car without waiting for the dash to do its flashy diagnostics and then starting it...
In the end I put in a new sensor... Never done it since..
For More Info Click To See;
« Reply #8 on: 28 January 2011, 11:12 »
dont just unplug the sensor, bridge the wires together as well. this will disable the level warning. leavign it unplugged will make the dash think coolant is low
Offline Ardz83
« Reply #9 on: 30 January 2011, 11:53 »
Yeah the garage did this and no good.
