Author Topic: golf mk3 leaking from sunroof......i think  (Read 889 times)
Offline IAN C
  • GOLF MK6 2012
« on: 25 January 2011, 21:36 »
just felt my 2 front seats and they are a bit damp. will this be an issue with sunroof or drainage.
GOLF MK6 tsi 2012
Re: golf mk3 leaking from sunroof......i think
« Reply #1 on: 26 January 2011, 10:09 »
open the roof and have a look in there, see if anything obvious. then pour a bit of water into each corner and make sure it drains away quickly, you'll see it coming out of the front/rear wheel arches. if one of the drains id blocked, try some bike cable or something similarly thin and pokey like. compressed air works too but be carefull you dont blow the tubes off the roof frame!
Offline VR6_Wherry
« Reply #2 on: 26 January 2011, 12:00 »
I pour carb cleaner, then use a straw up the nipple and then pour some water down  :smiley:
