Author Topic: Aftermarket 3 button keyfob/Immobiliser question  (Read 881 times)
Offline Seanl
« on: 24 January 2011, 21:25 »
Hi all, I have recently bought an aftermarket mk4 style flip keyfob. I have only just realised though, that it will have to be coded to the immobiliser. I also have an aftermarket central locking kit which I fitted just last week. My question is; can I just get the chip like is in the existing key and add it to the fob? Not sure how it all works! Cheers!
Offline boneybradley
  • Back in a Mk3...
Re: Aftermarket 3 button keyfob/Immobiliser question
« Reply #1 on: 24 January 2011, 21:41 »
you can try removing the transponder from an old key and glue it to the new one (but be careful as they break easy!)
« Reply #2 on: 25 January 2011, 10:06 »
yeah as above, i assume you bought the rclick kit yes? if so it has a nice little hole for the chip, just pop it out the old key and put it in the rclick fob. use some double sided tape or a blob o glue to keep it in place. oh, and note the orientation it came out your key, put it back the same way. i dont think it really matters but the mk3 chip has 1 corner missing so it will only fit 1 way in the mk3 key
Offline Seanl
« Reply #3 on: 25 January 2011, 15:36 »
ok thanks, better be really careful then cos I only have 1 transponder key!
