Author Topic: Mk3 Gti Multi Function Display  (Read 1354 times)
Offline clivusdel
  • Mk3 Golf GTi 8v
« on: 24 January 2011, 17:26 »
my M/F/D has decided to hide?
only some of the digits appear sometimes.
if button is pushed, you can see some digits still change, but un-readable.
any ideas what may cause this?
 :sick:
Offline Khare
  • The bear that khares
Re: Mk3 Gti Multi Function Display
« Reply #1 on: 24 January 2011, 19:09 »
Sounds like the display is fecked. Don't think you can change it individually, so new clocks time I think.
« Reply #2 on: 24 January 2011, 19:45 »
^^As above you will need to change the cluster
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #3 on: 24 January 2011, 20:40 »
someone said it may be a bad connection?
or maybe dampness?
Offline Khare
« Reply #4 on: 24 January 2011, 20:51 »
It's common for old plasma displays to mess up mate, it happens with age. Don't think damp or a bad connection would cause that.
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 24 January 2011, 20:55 »
you can try and re-plug them in (they can get loose)....although after several set's of mk3 clocks failing I guess like the other posters
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 24 January 2011, 21:29 »
not always, my mate had same prob and changed the stalk as it was faulty and it actualy sorted his display prob
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Pete93
« Reply #7 on: 25 January 2011, 10:00 »
Same here, I'm breaking the car atm so if your interested in getting a replacement pm me.  :smiley:
« Reply #8 on: 25 January 2011, 10:04 »
pull the dash fuse for 30 seconds then put it back in, or the battery -ve
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #9 on: 25 January 2011, 19:22 »
cheers will try that
