Author Topic: Heater fan help!!!!  (Read 1373 times)
Offline chrismk2
  • Mk2 16v
Heater fan help!!!!
« on: 24 February 2005, 18:39 »
Ive just bought a 91 mk1 gti cab and unfortunately the heater doesnt work. Upon investigation,after testing power at the switch and the fan itself both had power. Then removed the fan itself it was burnt out, i popped over to gfs to buy a new fan(?60) and it still doesnt work??????? there power both ends but nothings happening the fan works(i tested it 12v batt) its just not working am i doing anything wrong????? :huh:
Also i keep getting a litttle over run???how can i stop this?
cheers chris :sad:
« Last Edit: 25 February 2005, 00:53 by chrismk2 »
Offline Gambit
Re: Heater fan help!!!!
« Reply #1 on: 25 February 2005, 14:37 »
check the fuses for it, only other thing could be that you burnt out the speed selector switch though this is pretty rare
Offline Mr Blue
« Reply #2 on: 26 February 2005, 11:14 »
I used a large hammer and mine worked :laugh:
Offline chrismk2
  • Mk2 16v
« Reply #3 on: 26 February 2005, 16:07 »
Hi guys thanks for the help it turned out to be the solenoid pack on the front of the heater motor(mk1 bulkhead)
but only after 2 garages had had a look at it.....
sorted now though
chris :grin:
