Author Topic: im just curious of signs and symptoms of a bad water pump...  (Read 1277 times)
Offline daft
golf mk2 gti 8v
overheating and lack of hot air from the matrix usually, check the cooling system as per:
http://www.golfgtiforum.co.uk/index.php?topic=106380.0
Offline danny_p
they rumbel and leack,  then you overheat
all the VW's have gone bar 1.
Offline The Mighty Elvi
  • I'm better than you today.
OE ones have a plastic impeller.  The blades wear and can snap.  This produces a grinding noise from the pump if the baring goes and the blades rub the casing (as mine did).  New pumps have metal impellers.
Check for noise and leaks.  Cheap part from GSF and easy to fit.
