Author Topic: Help with Auto lights  (Read 4171 times)
Offline am1w
Re: Help with Auto lights
« Reply #10 on: 24 January 2011, 12:13 »
During the day my instrument lights vary with the outdoor brightness.
If it is bright they are bright and then as it gets darker they get dimmer until it it dark enough for the lights to come on and they come on permanently.
Same as mine.
I couldn't quite work out what was happening as the internal lights seemed to be on at times even although my external lights weren't.
Must check if this is happening with my car when I next drive it. :rolleyes:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #11 on: 24 January 2011, 12:25 »
I did think mine just have a mind of its own.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Mr Smooth
« Reply #12 on: 24 January 2011, 16:43 »
Thanks to everyone for their comments.
I have DRL's so the main beam is swithced on all the time (not sure if there is a separate bulb for the DRLs). I guess it works on the sensor and different lighting conditions and this can change all the time.
Also with the sun shining against the windscreen sometimes the controls lights are still illuminated :huh:
MK6 GTi DSG Tornado Red
Xenons,Sunroof,PDC Front & Rear,RCD510,LED Rear Tail Lights.
Offline Mr Smooth
« Reply #13 on: 10 February 2011, 12:41 »
Hi everyone
I was reading through the owner's manual and found the following:
"If your light switch is in position AUTO, the vehicle lighting and lighting in the instruments and switches will switch on and off automatically in the following situations:
Automatically switched on
When the light sensitive sensors detects darkness.
When you drive faster then 140KM/H for a few seconds.
When the rain sensor detects it is raining and switches the wipers on.
Automatically switched off
When the sensors detect there is enough light.
When you drive slower then 65KM/H.
When the windscreen wiper has not wiped for a few minutes.
I have tested the above and can confirm it is correct,so my problem is sorted.
Offline Mezza/golf6
« Reply #14 on: 18 June 2011, 18:30 »
Hello guys, can you tell me the code of  MK6  rear LED tail light?
 (The piece with the light of reversing)
Because I live in Italy and I want to do double the light at the rear of the machine.
 Thank you.
 You can also write to:
 Mezza.golf @ yahoo.it
