Author Topic: Boggin down  (Read 1197 times)
Offline gover87
  • mk3 gti 16v
Boggin down
« on: 23 January 2011, 17:54 »
My mk3 gti 16v is boggin dwn nw and again, it seems to slow down really quickly like the brakes are on but the engine like borps out if u get me, it just does it at random and havent gota clue.  The other week the balancing weight came of the driveshaft and i stuck it back on well, could this have anything to do with it. Its not the brakes its more like an engine or drive problem
Offline lemski
  • 16v
Re: Boggin down
« Reply #1 on: 23 January 2011, 18:18 »
Doesn't sound good that. Its not cutting the fuel like a temperairy blockage is it. Maybe tb needs a clean. New plugs. I'm just thinking simple mate
Offline gover87
  • mk3 gti 16v
Boggin down
« Reply #2 on: 23 January 2011, 18:26 »
I dont no mate, it like slows down really quick and when u try and put your foot down its like borping. Its wierd any more ideas lads?
Offline lemski
  • 16v
Re: Boggin down
« Reply #3 on: 23 January 2011, 18:33 »
i know my mate zr use to do it on occasion, u could be foot down, let off then go to overtake, and it would hesitate on power then just pick up and go, but that was his coilpacks, so a spark issue, but related to ecu. personally mate i'd be checking them simple things 1st to see.
Offline gover87
  • mk3 gti 16v
Boggin down
« Reply #4 on: 23 January 2011, 19:01 »
Well i cleand the throttle body not long ago, but il do it again and give a few other bits a clean up and see wot happens, cheers lads any 1else had owt like this?
Offline MiiTCH-GOLF
  • Low Life!!
Re: Boggin down
« Reply #5 on: 24 January 2011, 06:46 »
I think mines doing that!! But only on wet days but when it warms up it stops :s I'm gonna check the tb again I have done it once already but it's annoying because I went to pull off this morning and it sounds like a scooby lol then it just kicks In with power
Re: Boggin down
« Reply #6 on: 24 January 2011, 09:31 »
check the wiring to the TPS on the front of the throttle body,where it runsd along back of engine. it gets baked hard by engine heat and eventually splits and shorts out
Offline gover87
  • mk3 gti 16v
Boggin down
« Reply #7 on: 24 January 2011, 10:14 »
Sorry mate but wots the tps
Re: Boggin down
« Reply #8 on: 24 January 2011, 10:18 »
throttle position sensor, its the thing with a 3 pin plug :)
the 2 pin plug one on the back is your idle switch
Offline gover87
  • mk3 gti 16v
Boggin down
« Reply #9 on: 24 January 2011, 10:43 »
Ok mate il have a look cheers
