Author Topic: anybody no what this is?  (Read 2340 times)
Offline stainesy
Re: anybody no what this is?
« Reply #10 on: 23 January 2011, 15:08 »
Oh right. What problems can it cause? Actuly have noticed that now its back in its bracked my startor motor has hesitated a few times. Could it cause that?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 23 January 2011, 15:16 »
Is that the headlight resister?
Thats correct it causes the dipped beam to come on very dim when the sidelights are on. It often fails and the wires short on the bodywork causing problems.
Just remove it.
Yeah im sure ive read in the past about removing it although i can't remember for what exact reason now? By removing it what effect would it have on the headlight functions? Would removing it completely improve the power input therefore increasing light output?
Offline madmanmart
« Reply #12 on: 23 January 2011, 15:41 »
Removing it will make the sidelights work like normal. I doubt removing it will make power input greater for dip and main beam as its only used on sidelights.
The two connection wires can break off and short on the bodywork.
Bin it.....
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline stainesy
« Reply #13 on: 23 January 2011, 16:31 »
Ok just took it off. Didn't make any diferance to the lights what so ever.
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #14 on: 23 January 2011, 16:39 »
maybe its a metal tube with wires on it?
« Reply #15 on: 24 January 2011, 09:23 »
as above, its dim-dip resistor. the problem comes if it shorts to the chassis, more of an issue on the mk2 golf due to how wires are routed over the edge of the chassis leg which can be quite sharp. if it shorts out your headlight switch loom catches fire as there isnt a fuse
Offline mark-mk3gti
« Reply #16 on: 24 January 2011, 18:30 »
is this what you remove so the inner side lights go out when you have dipped on? i did try unplugging the yellow plug under air box but it made no difference, so could this resistor be knackered?
cheers
« Reply #17 on: 25 January 2011, 10:00 »
no it turns off the dipped beam when the sides are on, the sidelights will be on regardless of if this is plugged in or not :)
