Author Topic: what are the standard Brake disc sizes front and back?  (Read 9349 times)
Offline hennoir
Hi guys - lazy fecker here....(Rather than takin a couple of wheels off i thought i'd ask you knowledgable lot cos its dark outside!!)
Mines a completely standard setup on a 1999 mk4 turbo
Whats the standard size of the front and back discs?
I reckon its 288mm Vented on the front and 232mm Solid on the back. Is there a code on the sticker in the spare wheel well or service book that tells you which size is fitted ?
Chris (Hennoir)
Offline richw911
Re: what are the standard Brake disc sizes front and back?
« Reply #1 on: 23 January 2011, 10:32 »
Golf 1.8T Golf 130/150 TDI  :
The Front brakes are 288mm x 25mm Vented Discs,  54mm ATE single piston calipers
The Rear brakes are 232mm x 9mm Solid Discs
Golf Anniversary, VW Golf V5 170, VW Golf V6 4 Motion
The Front brakes are 312mm x 25mm Vented Discs, 54mm ATE single piston calipers
The Rear brakes are 256mm x 22mm Vented Discs, 38mm Lucas single Piston calipers
2.0 8v,1.8 20v N/A , TDI 115 , TDI 110 , TDI 100 , TDI 90 :
The Front brakes are 280mm x 22mm Vented Discs, Single piston calipers, caliper carrier integrated into hub
The Rear brakes are 232mm x 9mm Solid discs
 :smiley:
Offline hennoir
« Reply #2 on: 26 January 2011, 21:27 »
Many Thanks Richw911....sorry for late reply but only just managed to get back to looking at replies,
cheers
Chris
Chris (Hennoir)
Offline richw911
« Reply #3 on: 27 January 2011, 17:58 »
cheers
Chris
 :cool:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 27 January 2011, 22:45 »
no linky Rich ??
Offline richw911
« Reply #5 on: 28 January 2011, 17:31 »
no linky Rich ??
Not this time  :laugh:
