Author Topic: bit of advice please  (Read 2459 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 22 January 2011, 20:41 »
 hi right ive always wanted a mk1 cabriolet but im wanting a mk4 20vT engine put in and im going to do it all my self . just  before i go buy a mk1 and the mk4  engine gearbox ecu and loom etc etc  is this going to be a massive job with many nights up crying when the engine wont fit???  is there anything major i need to know before taking on the project ? thanx guys
Re: bit of advice please
« Reply #1 on: 22 January 2011, 21:25 »
Do a search, has been done so have a good read 1st and you should not face many problems
Offline seano7015
« Reply #2 on: 22 January 2011, 22:38 »
i want to do the same to mine!!   :grin:
travisreeve has put a thread on here about his mk1 conversion!! apparently you can buy the adapted engine mounts and a adapted wiring loom but its pricey!! but what isnt these days!! :grin:
sean :grin:
Offline lord14
« Reply #3 on: 22 January 2011, 22:49 »
almost completed a mk1 20v turbo , i brought the mounts off ebay for the gearbox, and made teh drivers side engine mount , brought the conversion shafts 100mm off ebay , but you need to make sure the mk4 has the 100mm gearbox flanges for them to work , i used the standard ecu and loom , then figures out how to wire it up by using jsut that loom , but then you need the ecu decoding , i can help you with the wiring its pretty simple
Offline matping
« Reply #4 on: 23 January 2011, 08:11 »
yes thats my worry the wiring  someone told me to use a  stand alone ecu ?? (plug and play  system ?)
im going to go for a AGU engine and gearbox   wont the 100mm flanges already come with this ?
 ill track down the mounts  and drive shafts on ebay then  unless you still have the link  you could PM me
oh and also for the ecu decoding . is this where you clear all the codes off it ? i have vag com if this helps or will i have to take it some where?  at the last stages of the engine build it will be remapped just going to do all the outher bits  first  upgrade the turbo,  front mount ,  TIP etc etc
 thanx for that
« Last Edit: 23 January 2011, 08:18 by matping »
Offline lord14
« Reply #5 on: 23 January 2011, 17:50 »
well i managed to wire the standard ecu in , by using just the agu engine harness , i sent the ecu off to a place called dna tunign and they decoded it for £100 ,. links arev            http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170552253434&ssPageName=STRK:MEWNX:IT#ht_1156wt_905 , mounts aren't on there anymore , but i think a place called caddy forum sell them , once your doing the wiring ill let you know step by step , through pm
