Author Topic: HELP whats happened?  (Read 2119 times)
Offline stainesy
Re: HELP whats happened?
« Reply #10 on: 22 January 2011, 18:16 »
Like i said.. the other end may well go to the valve/rocker cover..
ok cheers mate.
anybody no if it does? cant seem to find anything about it in haynes manual.
Christo77
« Reply #11 on: 22 January 2011, 18:20 »
No worries.. anyways just go have a look, you'll soon see if there's a vacant connecting point that suits the length and shape of the earth strap.
Sounds like it's worked loose and come off..
Offline stainesy
« Reply #12 on: 22 January 2011, 18:28 »
yeah looks that way but im more worried about the fact there is now a loud tapping/ticking sound from injectors/inlet manifold.
any ideas?
Christo77
« Reply #13 on: 22 January 2011, 18:35 »
Well yes if the coil isn't earthed it could well be causing the bad running and noises..
I had a bike many years ago that had an earth problem on the alternator/flywheel..i eventually found the issue but untill then it ran like crap and sounded like crap..and boiled the battery to overflow.
Christo77
« Reply #14 on: 22 January 2011, 18:52 »
Mate..just go start your engine and hold the dangling earth strap against the engine/valve cover.. i wouldn't mind betting your motor will suddenly sound healthy again   :wink:
Offline stainesy
« Reply #15 on: 22 January 2011, 18:58 »
Cheers a will try it in the morning. Thing is tho the car runs fine and I remember that earth strap has always been dangling. But sudenly now there is tapping. But idle and revs fine.
Offline stainesy
« Reply #16 on: 22 January 2011, 19:25 »
Ok I couldn't resist walking round to my garage with a torch to try this out.
Started engine. Opened bonnet left it running and result the tapping started to fade and just turned into normal injector sound.
Am thinking that when my coil died earlyer and I tried starting it so many times at road side maybe I did something to injector to make them noisy but they have sorted themselfs now.
I did find where earth strap goes so put it back on. Didn't make any diferance but hay atleast its back where it should be.
Cheers for the help guys. Much appreciated.
Offline Sii
« Reply #17 on: 22 January 2011, 20:03 »
Well the earth strap may well have caused the cutting out issue. If not it could well also be the infamous crank position sensor down by the oil filtre and front engine mount. The wires fray with age. got mine replaced and it cured my cutting out issues.
Hope it's cured anyway!  :smiley:
Offline stainesy
« Reply #18 on: 22 January 2011, 20:13 »
Yeah I bought a new crank position sensor last week but gave up when trying to fit it because I had hang over and it started to rain lol.
Also got a new coil today so am going to fit that tomorrow.
Realy can't be arssed to do crank sensor myslef as its a bast#rds job so gona get garage to change it.
Christo77
« Reply #19 on: 22 January 2011, 20:59 »
Oh well..no probs..anyway i believe it connects onto the apparatus on the end of the valve cover, which you've found i think  :wink:
And on that subject if you doubt the actual coil in anyway replace it..they have a habit of being a bit mysterious and packing up unexpectedly.
Bit of progress though eh..
Beg your pardon..see you've got a new coil.. top job.
« Last Edit: 22 January 2011, 21:08 by Christo77 »
